September 21, 2018 at 1:15 pm
rodmarti
SubscriberI am running an analysis that uses a failure criteria, but, when I visualize the results, the failed elements are shown, messing up the post processing. Is possible to suppress them in the results?
September 21, 2018 at 2:13 pm
Sandeep Medikonda
Ansys EmployeeEroded elements should be removed by default. What are your failure criteria?
Turn on, View>Eroded Nodes.
Sandeep
September 24, 2018 at 11:57 am
rodmarti
SubscriberI used max. strain of 0.16
I misinterpreted the results. The eroded elements are not shown (As you can see in the attached file).
In any case, there are elements that comply with the max strain but are too deformed.
Do you see anything strange in my results?
Thank you.
Rodrigo
September 24, 2018 at 2:15 pm
Sandeep Medikonda
Ansys EmployeeIf you are using reduced integration elements, I am not too worried about these. Keep an eye on the Hourglass Energy and on Energy conservation. It looks like these elements have a high aspect ratio even in the refined region, hence the stretching and odd shapes. Look at the mesh quality.
Try a maximum strain of 0.15 and see how much it affects your results. I believe you will see complete separation?
Sandeep
September 24, 2018 at 4:14 pm
rodmarti
SubscriberI am using low integration elements, so the analysis can run faster.
How can I check the hourglass energy in workbench?
Thanks,
Rodrigo
September 24, 2018 at 4:51 pm
Sandeep Medikonda
Ansys EmployeeRodrigo,
You can access this from the solution information. Please see below:
A general rule of thumb is to make sure that the Hourglass Energy is sufficiently small (about 10% of the Internal Energy)
Sandeep
September 28, 2018 at 2:14 pm
rodmarti
SubscriberThank you Sandeep,
I think I found out what the problem was. It turned out that it was simpler than that.
The erosion control for the material failure was not checked in the analysis settings.
One last question: In that model, I wasn't able to check the reaction forces. Is there another way to do that?
Rodrigo
September 28, 2018 at 3:54 pm
Sandeep Medikonda
Ansys EmployeeHi Rodrigo,
You can look at it from here:
Also, what version are you using? I would recommend (and personally tested this in) you to use 19.2 and turn on beta features. You can activate beta features from Workbench in Tools>Options>Apperance.
Sandeep
September 28, 2018 at 3:57 pm
rodmarti
SubscriberSandeep,
I am using version 18.1
I'll check with the university if it is possible to upgrade the version.
Problem solved!
Thank you!
Rodrigo
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2564
2080
1299
1106
459
