Preprocessing
Preprocessing
How to switch from SOLID69 to SOLID226for thermal electrical analysis ?
    • ba_pansiot
      Hello, I am trying to update a large APDL code and switch from SOLID69 to SOLID226 for a thermal electrical simulation. The code is running and I obtain a result. However, the results are quite different from the one with SOLID69. What could cause this considering that all other parameters are being the same?
      Thankyou.
    • Aniket
    • ba_pansiot
      Yes. Also, the mesh parameters are kept the same as well as solver parameters.
