November 15, 2020 at 9:56 am
mustafadundar
SubscriberHi anyone; nI want to tensile test graph. Bu I don't konow how to create Tensile test graph on ANSYS. Can I help you? n -
November 18, 2020 at 2:51 pm
Dragana Jandric
Ansys EmployeenIf you want to plot Stress/strain after the solution, you can use Chart and plot Normal stress in Y/Total mechanical strain in Y. First use user defined results and get the Normal stress in Y and total strain in Y for one node, then use Chart scoped on these two objects. Please see the images of the dog bone example below. nSelect a node in the circled region nUse User Defined results for that node to get Normal Stress in Y for that node. Do the same to get the Total strain in Y for that node.n
Then insert Chart. For the Outline Selection in the details view - select Normal Stress and EPTOY and apply, then select entities that you would like to plot (Output Quantities) n
n
February 2, 2021 at 9:08 pm
Chihi
Subscriberi have the same problem but on Mechanical APDL Ansys Classic. Could you help me aswell to get the same graph aswell ?nthank you!n
- A solver pivot warning or error has been detected
8808
4658
3151
1680
1470
