3D Design
3D Design
How to transfer design parameters of SolidWorks through spaceclaim
    • d dg
      I have a truss structure that needs parameter optimization, and the parameters from SolidWorks are usually easily imported into wordbeam through the design module. But this time I hope to use spaceclaim to optimize the truss, and the transfer of parameters seems to be over.
    • Gary Stofan
      Both SpaceClaim and Discovery are able to import CAD Parameters from a CAD plugin.
      You must start from the Workbench Project Page, attach to Active CAD Geometry then Edit in SpaceClaim (or Discovery).
      In SpaceClaim the feature is Block Recording. Discovery it is called History Tracking, but function is same.
      History Tracking (ansys.com)
      I suggest starting with a simple CAD Parameter part with a few parameters to confirm the operation.
      In my example, I have a simple parameter with DS in the CAD Parameter name.
      If CAD parameters are detected, SpaceClaim will automatically display the Block Recording Panel.
