How to transfer heat in a tank using moving heat flux
    • Sahan
      Hello! I'm modelled the pressure tank with thin surface using steady-state thermal. The thickness is 5mm. I'm having problem about estimation of internal temperature behavior of the geometry, I put a plate (thin surface) at the middle of the geometry to check the thermal behavior.
      But problem is I cannot transfer heat from outside to inside. Can you help me how to solve this problem.
    • Ashish Khemka
      Please see if the example of oven provided in the Course below helps you:
      Thermal Radiation Simulation Examples | Ansys Courses
      Regards Ashish Khemka
