August 29, 2018 at 3:26 pm
KumarVaibhav
SubscriberI meshed a geometry in ansys component systems but now i am unable to transfer the mesh part to explicit dynamics project schematic exceppt the geometry.Why is it so?is there any way to transfer or not.See the screenshot
August 29, 2018 at 10:03 pm
SubscriberIsn't Mesh intended for Fluids?
August 30, 2018 at 6:27 am
KumarVaibhav
Subscriberno i did it because of unable to mesh in mechanical so i was just fiddling with it
August 30, 2018 at 10:27 am
Ansys EmployeeYou may be able to export in Meshing to then import into Explicit but the mesh type may not be suitable.
However, I would strongly recommend taking a step back, and working through (on paper) what you're trying to do. Then open Workbench and use the correct Analysis System and follow the steps you wrote out through that.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2098
1323
1108
461
