September 26, 2018 at 8:15 am
Subhash N
SubscriberI am trying to simulate the machining operation in ANSYS from the survey Arbitrary Lagrangian and Eulerian approach for meshing was appropriate for this simulation. so how can I incorporate that approach in my simulation model.
September 26, 2018 at 11:03 am
Ansys EmployeePlease can you explain in more detail, and add some images?
September 26, 2018 at 1:27 pm
Keyur Kanade
Ansys EmployeeIt would be good to have more explanation about
what you are trying to do?
what is the process you are using?
what tools you are using?
Please insert images which would be more useful.
Keyur
September 26, 2018 at 5:18 pm
September 26, 2018 at 7:56 pm
September 29, 2018 at 2:56 am
Subhash N
SubscriberSir, what all the information you need?
September 29, 2018 at 4:08 am
Sandeep Medikonda
Ansys EmployeeHi Subhash,
It looks like an Explicit Dynamics problem as we previously discussed. You can use the Euler domain (set Euler Reference in the geometry details) and change controls as needed in the Analysis settings. Check out this section from the manual for the theory behind it and the coupling?
Sandeep
Best Practices to post on the Student Community -
October 1, 2018 at 5:11 am
Subhash N
SubscriberSir,
Thank you for responding
I'm getting an error like energy error too large . What might be the cause of it How can I solve it.
October 1, 2018 at 1:49 pm
Sandeep Medikonda
Ansys EmployeeSubhash,
Look at the energy conservation and energy summary in the output of your model. This might give you a better idea.
Sandeep
October 1, 2018 at 4:03 pm
Subhash N
SubscriberOk sir,
Can you tell how to incorporate the effect of coolant in the same machining process.
October 1, 2018 at 6:51 pm
Sandeep Medikonda
Ansys EmployeeHi Subhash, As far as I am aware you cannot model Thermal Conductance in Explicit Dynamics, you might have to use WB LS-DYNA.
Sandeep
October 2, 2018 at 11:12 am
Subhash N
Subscriberok sir, Thank you
December 12, 2018 at 1:51 pm
Anshu
SubscriberHello community
I want to simulate same problem in apdl .Please tell me how to define johnson cook model in apdl.
Thanks in advanced
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2522
2064
1279
1094
456
