Discovery Import
Discovery Import
How to use command lines to call programs in ANSYS Discovery Live?
    • hanjian
      The engineer in our lab has been using ANSYS Discovery Live recently and he met a problem. He wanted to use command lines to call programs. As the picture showed, he wanted to embed ANSYS Discovery Live in his own software. The three numbers on the left represented the characteristics of the stove showed on the right. He was wondering how to use command lines to "pass" the parameters from his software to ANSYS Discovery Live, which means if someone changes the number on the left, the number which is changed can be "transported" into ANSYS Discovery Live. It will help us a lot if you can contact me(hanjian@ipe.ac.cn).Thank you.
    • Subashni Ravichandran
      Hi
      I will consult the team and get back to you.
      • hanjian
        Subashni Thank you. That will help us a lot.
      • hanjian
        Subashni Hello, is there any progress on this problem? We can't wait to hear about you on the solution to this problem? Thank you.
        We are looking into this. The team will contact you via email soon
