August 3, 2022 at 8:46 pm
mo_911
SubscriberHello,
I just wanted to use the sample for "Inverse Design of a Splitter Using Topology Optimization" (https://optics.ansys.com/hc/en-us/articles/1500007182141).
According to the Lumerical's presentation file that I have attached below, the optimization depends on the initial conditions. So, I would like to change the initial condition as shown in the slide.
The initial conditions for "Filled", "Empty", and "Average" are available in the python script as I have attached the screenshot below. However, the initial condition for "Naive Splitter" is not available. How could I use "Naive Splitter" as an initial condition for both 2.5D and 3D optimizations? Sometimes this condition had the best solution.
August 4, 2022 at 5:20 pm
Taylor Robertson
Ansys EmployeeHello,
I believe that by the naive splitter you mean this sort of structure?
You can see that this structure, is actually part of a structure group with the name initial_guess. To define your own initial guess in a structure group of the exact same name. Then to use this as your starting point you set initial_cond = None in the python script. This is a special value that tells Python to mesh this structure and use this as a starting point, this is noted in the comments. You could also do this using an np array, but that would be a bit more challenging, because you need to match the simulation grid exactly.
Alternatively if you want to restart from a previous solution you could use the method outlined in optimization continuation.
Best Regards,
August 4, 2022 at 6:38 pm
mo_911
SubscriberHello,
Yes, this is what I wanted to do. Sorry, I overlooked the comments. In the python script "splitter_opt_2D_TE_topology_minfeaturesize.py", I set initial_cond = None. Then I was able to use the initial_guss structure as an initial guess for 2.5D topology optimization. Thank you for your help!
However, this method did not work for 3D optimization. In the python script "splitter_opt_3D_TE_topology_minfeaturesize.py", I set startingParams = None and set start_from_2d_result = False not to use the 2d result as shown below.
After running the python script, I got errors on the python terminal window as shown below. It looks like the FDTD grid and the initial_guess pixel size do not match. How can I resolve this mismatch?
August 25, 2022 at 5:50 pm
mo_911
SubscriberI am still wondering how to use a naive splitter as an initial guess for 3D topology optimization. As I told you, your sample python script is not working with this option.
I tried to use polygons defined by lsf script as an initial guess for 3D topology optimization, but I got an error as well.
- Error on Lumerical device
2656
2120
1345
1118
461
