How to use PML in Ansys workbench ?
    • Wond
      Please how can I use PML layer in Ansys workbench for a harmonic analysis ? thank you for your help
    • Erik Kostson
      Hi
      We need to model the air and a box/enclosure surrounding the air which will be the pml region(share topology between them - see image below).
      Then define physics region for both the PML box and the air (so two acoustic regions - see below), and the one for the PML enclosure set it to PML under the physics region settings (see below).
      See below for details:
      All the best
      Erik
    • Wond
      I will try it, Thank you for your reply
    • Erik Kostson
      Hi -
      Have in mind PML only exists for acoustic elements in harmonic in the mechanical ui. SO the above image is for harmonic acoustics.
      For solid187/186 elements we need to change a key option (keyopt 15=1) for the element - see the help manual and the element reference and search in there for PML.
      All the best
      Erik
Viewing 3 reply threads
