April 26, 2023 at 5:17 pm
KENNY WU
SubscriberHow to use pwl with load torque varies with rotate angle(will higher than 360 degree)?
My input is load torque(varies with rotate angle) and moment of inertia to simulate and analysis.
The load torque setting which I used is pwl(loadtorque, Ang), but the report of load torque isn’t change by the time
Is “Ang” to be used in this condition, what the means of the 'Ang' ? or needs to used another variable? or there has another method to reach the goal -
May 3, 2023 at 7:49 am
GLUO
Ansys EmployeeHello,
Please use "Position/1deg" instead of Ang.
GL
May 3, 2023 at 4:01 pm
KENNY WU
SubscriberThanks for your help💯
- Maxwell, HFSS or Q3D?
- Error
5404
3379
2471
1310
1022
