May 19, 2023 at 2:38 pm
Suruchi bala
SubscriberI am using Spontaneous Four-wave Mixing (SWFM) Microring Resonator Photon Source – Ansys Optics example. While running this example, I am getting an error in python that it is not able to 'import qsolver from qinterconnect'. In the saved python folder of lumerical, it has .pyd file of solver which can't be used in running the code. How to use qsolver in this example?
Also, the example zip file has no rib waveguide file, is this the same as other rib waveguide used in simulation for other examples?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5162
3275
2453
