Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
How to use reinforcing section in MAPDL?
    • Zaid Abd Al-Hadi
      Hey!
      Im trying to model a composite plate using layered element SOLID185 an REINF265.
      the code:
      MP,EX,1
      MP,NU,1
      MP,DENS,1
      MP,EX,2
      MP,NU,2
      MP,DENS,2
      ET,1,SOLID185
      KEYOPT,1,3,1         !LAYERED SOLID
      MAT,1
      ESYS,0
      SECNUM,1
      SECTYPE,1,SHELL
      SECDATA,0.001,1,45, ,L1
      SECDATA,0.001,1,-45, ,L2
      SECDATA,0.001,1,-45, ,L3
      SECDATA,0.001,1,45, ,L4
      BLOCK,0,0.1,0,0.1,0,0.004        !PLATE WITH 100X100X4 (mm)
      ESIZE,0.001
      MSHKEY,1
      MSHAPE,0
      VMESH,ALL
      SECTYPE,2,REINF,SMEAR
      SECDATA,2,1.97E-13,0.00000057205,0,0,LAYN,1
      SECDATA,2,1.97E-13,0.00000057205,0,0,LAYN,2
      SECDATA,2,1.97E-13,0.00000057205,0,0,LAYN,3
      SECDATA,2,1.97E-13,0.00000057205,0,0,LAYN,4
      SECCONTROL, ,1, ,
      ESEL,ALL
      EREINF
      when the reinforcing section is defined as "2", (i.e sectype,2,reinf), it gives error: the specified reinforcing section 2 for section 2 is a LAYn pattern with layer number greater than one and must be overlaid with a shell.
      if the reinforcing section is defined "1", it gives error: reinforcment No.2 in section 1 for REINF element xxxx specifies a layer number which is greater than the total number of layers defined for the base element 2.
      despite, my goal is to use a shell section and a reinforcing section in the same element, what is the best way to do this?
      thanks in advance
    • Ashish Khemka
      Please see if the following link helps: 9.8. Recommendations (ansys.com)
      How to access the ANSYS Online Help
      Ashish Khemka
      • Zaid Abd Al-Hadi
        Dear Ashish,
        could you please help me and write the correct commands, as I still didnt manage to get it right.
