Photonics
Photonics
How to Verify phase?
    • miaomiao1489
    • Guilin Sun
      I believe that you are referring their phase difference, not the absolute phase? The phase difference can be any value from zero to 2pi or -pi to pi.
      Your idea should work so please try.
      Phase is associated with a frequency and a field component.
      BTW: be careful when using a point monitor, as its result may be sensitive to mesh. When you change the mesh accuracy, make sure the point monitor is located at the same position of the mesh, eg, at the mesh point for a giving field component:
      If the image cannot display please refer to this page about Yee Cell.
    • miaomiao1489
      Thank you very much for your reply.
