April 2, 2023 at 11:11 am
Pratik Deb
SubscriberHello all,
So, this is a very basic level question. I was designing a 50ohm micristrip line at 5GHz frequency using Ansys HFSS in Ansys Electronic Desktop 2022-R2 with the help of this youtube video (https://www.youtube.com/watch?v=LOQePJnB_9Q&ab_channel=RFDesignBasics). The video uses this link to calculate the dimensions for the substrate and the copper trace: https://www.emtalk.com/mscalc.php.
Now, my question is, how do I verify that the design is actually a 50ohm microstrip line? Do I plot the Z parameters (Z(1,1)) to see if there is peak at 5GHz of 50Ohms? I did that but the value of Z(1,1) is not 50ohms.
Thank you!
April 3, 2023 at 1:24 pm
Connor Pope
SubscriberTry plotting the time domain reflection (TDR) of your microstrip line. If you switch your domain from "Sweep" [the name of your Analysis] to "Time" you can then plot the TDR.
Once you've selected "Time" as your domaine, you can selected "Terminal TDR Impedance" which will plot the time domain reflection vs time. For a straight microstrip line it should be relatively flat. You can switch the settings for the TDR plot under "TDR Options..." which should be ungreyed after you switch your domain to time.-
April 22, 2023 at 1:07 pm
Pratik Deb
SubscriberHello,
Thank you for your response. I did not have the option to plot "Terminal" parameters like your screenshot when I switched to time domain but there was an option to plot TDR impedance (See screenshot below):
So I plotted the TDRZ(1) (abs) (Screenshot below):
So, since at the 0 sec, we can see that the TDRZ(1) value is 49.5 ohms, this is how I verify that my microstrip line structure is actually 50ohms, right?
Again, thank you for your help.
April 3, 2023 at 8:35 pm
Dan Dvorscak
Ansys EmployeeAnother viable option would be to export the s-parameter model into AEDT Circuit and use the TDR probe in that tool. Which has the advantage that if you are looking to include this as part of a larger channel model, you can include those models as well to get a feel for the entire strucutre.
April 22, 2023 at 1:10 pm
Pratik Deb
SubscriberThank you. I have used Ansys Circuit Design before where I had took my model from HFSS to Circuit Design and added passive elements there and used the option "push excitations" and later observed results in HFSS again. I don't have much experience in using the Ansys Circuit Design option but I will try to do what you suggested.
April 24, 2023 at 6:02 pm
Dan Dvorscak
Ansys EmployeeHi Pratik. Ah, pushing excitations back to HFSS is really only used for field plotting. It does not impact results like s-parameters or TDR plots. To do a TDR of that combined structure, you must do it in the Cicuit tool. There is an example TDR project in the examples in the Circuit/Signal Integrity folder if you need a reference.
April 24, 2023 at 6:04 pm
Pratik Deb
SubscriberHi Dan, thank you for the explanation. Any chance you could link those TDR example projects that you just mentioned?
April 24, 2023 at 6:45 pm
Dan Dvorscak
Ansys Employee-
April 24, 2023 at 6:49 pm
Pratik Deb
SubscriberThank you Dan! I thought you meant examples from the Ansys Learning Hub website, that's why I had asked for a link. I will check out these examples.
- Maxwell, HFSS or Q3D?
- Error
5162
3273
2443
