How to visualize discrete particles in different 2D planes from a 3D discrete particle simulation?
    • taosif_alam
      Hi all,
      I am doing a 3D Unsteady Discrete particle simulation in Fluent. I want to visualize the particles on different 2D planes (i.e. at different x locations). Is this possible on Fluent ?
    • ai0013
      You can display the particle tracks -> Filter -> Filter by coordinate (chose the axis that is perpendicular to your plane). Bound the coordinate values by a small thin slice, lets say - 1 mm (into your plane) and + 1 mm (out of your plane).
    • RK
      Thank you for posting the solution.
    • DrAmine
      Thanks for posting a solution to this :)
Viewing 3 reply threads
