January 2, 2020 at 1:45 am
xiaoling
SubscriberHi all,
I want to test the result of the below-coupled case, which is using Ansys workbench. However, at my side, I can only use the CFX modules, that only include the pre, solver, post parts. Then, I am thinking, I can export the def file from the C4 cell in the workbench and import it to my pre CFX part, but as you can see, there is a link between B5 cell and C5 cell, and I don't know how to get this information into my CFX module.
January 2, 2020 at 1:46 am
January 2, 2020 at 3:33 pm
Forum ModeratorWhat are you trying to model?
January 3, 2020 at 11:36 am
January 6, 2020 at 4:01 pm
Forum ModeratorIf you're just looking at standard heat transfer between a fluid & solid you can do the whole calculation in CFX or Fluent. You only need to add the Mechanical tools if the flow/temperature effect on the solid shape or stress is needed.
- The topic ‘how to work it in a CFX solver’ is closed to new replies.
- fluent, RMS and RMSE
- to restart the analysis from previous file when it already reaches 10000
- Floating License does not work
- Restart ansys simulation
- Element located in body is highly distorted
- Modelcenter MBSE via Cameo: passing part properties
- where do I found the installation for ANSYS Workbench in the download center?
2878
970
852
599
591
© 2025 Copyright ANSYS, Inc. All rights reserved.
