how to write a command in ansys workbench for applying multiple loads on nodes
    • saiprathap123
                I am modeling a simply supported beam in transient analysis in ansys workbench with mess 4 element and 5 nodes. now i want to apply multiple nodal forces on the nodes (nodes 1 to 5) of the beam with respect to time. Now i am analyzing a single load case every time separately it is taking more time to analysis. So i want to write a command to analysis all loads at a time. How to write the command in workbench and in which format i should write the command. Can you give me any suggestion to write the command.
Viewing 0 reply threads
