November 14, 2019 at 10:54 am
MohammadUT
SubscriberQuestion: How can I make solver not to further in time after Max Iteration/Time step is done, and repeat the calculation with new B.C.s at same step of time util a criterion is met?
more information:
I have two simple equations which determine the pressure and velocity at the inlet and outlet of my CFD domain. Starting with an initial guess for these values, I want to couple these values to the result of Fluent and in each time step perform a loop till the values predicted by equations drop in a specific range of those predicted by Fluent.
So, basically I want to perform a loop without solver going to the next time step until a certain residual is reached.
Please notice that in a steady state solver DEFINE_PROFILE and DEFINE_ADJUST updates every iteration and in a transient solver every time step. -
November 14, 2019 at 11:35 am
Ansys EmployeeIf you're altering the inlet & outlet conditions to suit an external model what are you solving in the Fluent case?
November 14, 2019 at 11:52 am
MohammadUT
Subscriberwhat I know from the B.C.s is the relation between Pressure and Flow rate as follow:
from Method of characteristics (external model):
Inlet: H=known and Q=unknown;
outlet: H(outlet)=C(a known constant) - D(a known constant)*Q(outlet)
constants are obtained from values of H and Q at previous time step.
I want to couple these equations to fluent case and obtain the pressure drop = H(inlet)-H(outlet) as well as Q.
So basically the loop that I want to perform in each time step is going to find the H(outlet) and Q.
November 14, 2019 at 1:35 pm
Ansys EmployeeThe CFD model geometry will give the relationship between pressure & flow. So you want to alter the outlet pressure and find the flow rate at that pressure? Given it's transient I have no idea how this will work (physically or computationally) as you're also working within a finite time with changing values.
Work through the logic and sketch out the physical process: that may make it easier to understand.
November 14, 2019 at 3:06 pm
MohammadUT
Subscriber -
November 14, 2019 at 4:27 pm
Ansys EmployeeThanks, I'm not sure you'll be able to do that within a time step. Run the system without the MOC loop and monitor pressure & flow to see what you get.
November 14, 2019 at 7:59 pm
MohammadUT
SubscriberI know it can be done with Scheme programming (don't know how!), but is there any way to set flow time in UDF? Can I remain flow time constant till convergence of the above image is reached.
like:
(rpsetvar 'flow-time 0.2)
November 15, 2019 at 11:50 am
Ansys EmployeeYou can call/push scheme from a UDF.
5454
3401
2473
1310
1022
