December 19, 2022 at 12:41 pm
Ingmar van Dijk
SubscriberHi all,
Experienced engineer but notive programmer here. I code directly into the python console in ansys mechanical. I'd like to make some functions I can always import and call to clean up my code.
However, a standard function doesn't know what to do with ANSYS commands.
Can somebody help me write this example:
The external function is something like:
def lights():
ExtAPI.DataModel.Project.Model.Ambient=0.4And I call it like this:
#Import sys for system and imp for importlib. In Python3 it is importlib instead imp.
import sys
import imp#Set your path where your python files are, for example my test folder for random ansys stuff
path = r"R:\OF_EN\SUS\_DOC\Tools\FEA\700-FEM-ANSYS-Python\Mech-Functions"#Check if path exists. Without check it will always add the path and create a bunch of bullshit
if path not in sys.path:
sys.path.append(path)#Import your library you want
import TestFunction as tester
#import SetLightning as lights#IMPORTANT: reload your library. If you dont, you dont see changes in your code
imp.reload(tester)
#imp.reload(lights)tester.lights()
This of course doesn't work as the function is trying to perform a function that doesn't do anything at that external location.
Help on how to fix this is much apprechated!
Thanks in advance,
Ingmar
2098
1323
1110
461
