March 5, 2022 at 6:43 pm
maxning
SubscriberI have set up parameters for my fluent simulation. However, when I click "save output parameter" for "force" and "moment" output, the parameter are only for the force and moment, without the coefficients. Could you tell me how to output the coefficients as the parameter instead?
March 7, 2022 at 10:27 pmKarthik R
AdministratorHello:
When you create the report, could you make sure that you are picking the "Moment Coefficient" and not "Moment" from the Report Definition dialog box?
Karthik
March 8, 2022 at 12:57 ammaxning
SubscriberCould you tell me where did you find this "moment coefficient"? I can only see three option in the "force report"--force ,moment, and center of pressure
March 8, 2022 at 11:38 amDrAmine
Ansys EmployeeAre you using report definition to create Moment report?
March 8, 2022 at 9:41 pmMarch 9, 2022 at 12:47 pmKarthik R
AdministratorHello:
Please use Solution -> Reports -> Definitions -> New -> Force Report -> Moments. You should be able to set an output parameter this way.
Karthik
March 9, 2022 at 2:00 pmDrAmine
Ansys EmployeeReport Definitions are your friend and helper here!
March 9, 2022 at 3:13 pmMarch 10, 2022 at 2:07 pmDrAmine
Ansys EmployeeDoes the error occur if you create a new report? Does it occur in a Wb project started from scratch?
Viewing 8 reply threads- You must be logged in to reply to this topic.
2684
2122
1349
1136
461
