Ansys Products
Ansys Products
How to write in “CFF” format when launching Fluent through workbench?
    • tyw7
      Whenver I launch Fluent through workbench and do a mesh optimization I get the warning Mesh adaption information is only written to case files in ANSYS common fluids format (CFF). It is recommended that you write the case in CFF format.nnHowever, it seems there's no way to write to .h5 when using Workbench.nnWill my optimizations be lost if I save it in the default format?n
    • tyw7
      It seems that to save in CFF format, I have to type in [filename].cas.h5n
      If you look in preferences you should be able to change it there too. n
    • tyw7
      I can't find it in preferences. I am loading Fluent through workbench.n
      Having checked, it's missing. CFD Post didn't like h5 format so that's probably the reason. It's here in the standalone preferencesnnn
Viewing 4 reply threads
