August 31, 2018 at 6:55 am
Devank12
SubscriberI want to define Density of water that varies with temperature I have written a UDF based on the following polynomial equation. I donot know it is right . If anycorrection plz inform me. Thanks
#include "udf.h"
DEFINE_PROPERTY(cell_density,cell,thread)
real rho;
real T = C_T(c,t);
rho = 765.33+1.8142*T – 0.0035*pow(T,2.)
C_UDMI(c,t,0) = rho;
return rho;
August 31, 2018 at 10:03 am
DrAmine
Ansys EmployeeHelp your self by using debugging messages. You have started with writing into UDMI's that if fine. You need to use the cell pointer and cell thread pointer passed by Fluent. Actually you don't need an UDF as you can use the polynomial option there.
September 10, 2019 at 1:33 pm
RagnorakMan
SubscriberHi Devank,
While this post is a year old but I've recently tried out your udf but for a solid. Just remember to change the cell and thread to c & t eitherwise FLUENT wouldn't recognize the other variables.
#include "udf.h"
DEFINE_PROPERTY(cell_density, c, t)
real rho;
real T = C_T(c,t);
return rho;
September 10, 2019 at 2:12 pm
DrAmine
Ansys EmployeeWhy using an UDF to do just a temperature dependent density. Just use polynomial law in Fluent.
September 12, 2019 at 5:18 pm
RagnorakMan
SubscriberBecause I'm trying to model a phase change material but as a solid. The drop down menu does not provide me with a polynomial function. Only the specific heat capacity and the thermal conductivity
September 13, 2019 at 6:34 am
DrAmine
Ansys EmployeeYou need to define that solid as a fluid in order to use phase change models or any phase-change related UDF.
2700
2138
1355
1142
462
