August 29, 2018 at 3:29 pm
August 29, 2018 at 6:54 pm
DrAmine
Ansys EmployeeSearch in the Fluent customization for the macro DEFINE_PROPERTY and create the expression for the viscosity,
August 30, 2018 at 12:29 am
klu
Ansys EmployeeAdd to abenhadj, the macro to access cell temperature is C_T(c,t).
August 30, 2018 at 5:41 am
seeta gunti
Ansys EmployeeHello Devank,
You can refer Fluent Customization documentation under "Detailed Examples". In that, DEFINE_PROPERTY macro is explained with an example of a variable viscosity profile to simulate the solidification. You can try the similar UDF with dynamic viscosity profile. Hope this help you.
August 30, 2018 at 7:07 am
Devank12
Subscriber#include "udf.h"
DEFINE_PROPERTY (cell_viscosity,c,t)
real mu;
real temp = C_T(cell, thread);
mu =2.414*e-05* double pow(double 10, double 248/T-140);
return mu;
i have developed a UDF for dynamic viscosity . i dnot know which is correct. if any correction plz inform me
August 30, 2018 at 7:23 am
Nownesh
Ansys EmployeeHello
In DEFINE_PROPERTY (cell_viscosity,c,t), and real temp = C_T(cell, thread);... c,t and cell & thread names should be consistent.
August 30, 2018 at 8:18 am
DrAmine
Ansys Employee#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
real mu = 1e-5;
real fac = 1.0;
fac = 248.0/(C_T(c,t)-140.0);
mu =2.414*exp(-0.5)*pow(10.0, fac);
C_UDMI(c,t,0) = mu;
return mu;
Please check the customization manal and attend a UDF Training.
May 10, 2019 at 8:52 am
dsub5
Subscriberhello everyone. i have to create udf for dynamic viscosity and thermal conductivity coefficient. but have no idea about codes.
here is the formulas. if anyone can help me, i wii be glad.
mu=(3.4*10^-7*T^2)-(2.3*10^-4*T)+(3.9*10^-2)
k=0.004961*T-0.8078 -
August 17, 2019 at 11:37 am
ziadkoussa
Subscriberhello,
i am running the same udf you posted as i need the same values however after i interpret the udf and change the viscosity to user defined, when i try to initialise and calculate i get an error message saying "f1 process could not be started" and fluent automatically closes.
Help please
August 19, 2019 at 5:06 am
DrAmine
Ansys EmployeeTry to compile. -
August 19, 2019 at 8:53 am
ziadkoussa
SubscriberHi Amine,
thank you for your help.
Is there anything i need to change in the code to compile? (I am still new to ansys)
Thanks
August 19, 2019 at 9:34 am
DrAmine
Ansys EmployeeYou need to install a compiler. Check in the forum for several Compiler threads. In your case your using the UDF I Posted I guess. Please check if you have defined a User Memory in Fluent.
September 27, 2019 at 10:58 am
Eirene2015
SubscriberWrong help provided by abenhadj,
made me go through a whole day learning how to compile the UDFs, but the issue is the fact that his syntax is wrong.
C_UDMI(c,t,0) is not defined yet, so you cannot allocate values to it, thus the user receives a segmentation fault error!
This UDF does not require compilation. A simple interpret will work as long as the issue of C_UDMI(c,t,0) is omitted.
Do not wast time in compiling this code as I did!
2656
2120
1347
1118
461
