August 31, 2018 at 6:59 am
Devank12
SubscriberI want to define SPECIFIC HEAT of water that varies with temperature I have written a UDF based on the following polynomial equation. I donot know it is right .If any correction plz inform me. Thanks
DEFINE_SPECIFIC_HEAT(specificheat, T, Tref, h, yi)
real cp,;
real T = C_T(c,t);
cp = 28.07- (0.2817*T) +(1.25*exp(-3.0) *pow(T,2.))-(2.48*exp(-6.0) *pow(T,3.))+(1.857*exp(-9.0) *pow(T,4.))
C_UDMI(c,t,0) = cp;
return cp;
August 31, 2018 at 10:05 am
DrAmine
Ansys EmployeeHelp your self by using debugging messages. You have started with writing into UDMI's that if fine. You need to use the temperature passed by Fluent. Morever in the manual you have an example for DEFINE_SPECIFIC_HEAT. Actually you don't need an UDF as you can use the polynomial option there.
September 10, 2019 at 12:42 pm
RagnorakMan
SubscriberHi Amine, would you know what type of units are used for a specific heat capacity based UDF? I'm trying to define a solid with the UDF posted by Devank and I've noticed that his units are kJ/kgK whereas the standard units within Fluent are J/kgK. Your advice will be helpful
September 10, 2019 at 12:52 pm
Ansys EmployeeIt'll use SI units: likely J/kg K.
2600
2088
1317
1108
459
