how to zoom out and have proper user interface
    • AbdelrahmanSherif
      Hi, I'm quite new to the whole simulation and ansys, I've been watching some tutorials on YouTube and I've had normal interface before I don't know what happened but it seems like my fluent is zoomed in, and I can't see the console under the graphics I just want to make things smaller
      this is my current interface
    • Keyur Kanade
    • AbdelrahmanSherif
      actually I did but it's still not zooming out I'm not just trying to get the console below the graphics but also want to zoom out, the text is so bign
      Text looks about right. Check screen resolution and scaling in the Win10 Display settings. n
    • AbdelrahmanSherif
      I provided 2 pictures, first is mine and 2nd is how it used to be, it's not from windows, I don't know what happened but I'm even facing problem seeing the console unless I move it up sometimes, sometimes I can't press calculate button unless I move the console next to it so it squeeze it more, something is quite wrong but I've no idea how it did happenn
    • YasserSelima
      in the top right corner, the icon that looks like the document ... click on it and select the view you like.n
    • AbdelrahmanSherif
      this doesnt zoom out I can't click on calculate or increase the number of iterations unless i bring the console up theren
      You're showing images of Fluent Meshing, there isn't an iterate button to bring up. Re the top menus in Fluent Meshing, the above tends to happen when the graphics resolution gets scrambled: you can try renaming the %appdata% file/folder that's linked to 2020R2.n
    • AbdelrahmanSherif
      here is a screen from the solution zooming in too much, can't see the console below when I go to results I can't click calculate unless I drag the console next to the top menu which obviously isn't how ansys work, Idk the exact problem but it need to zoom out 25, or 50 %n
Viewing 8 reply threads
