Preprocessing
Preprocessing
How togenerate a good structural mesh when using Ansys Fluent with meshing node from the workbench.
    • kymani_Brown
       have been going through the " Ansys How To Videos" and been trying to generate a mesh that is high quality, however, I don't see a way that I can generate a good structural mesh when using Ansys Fluent with meshing node from the workbench. I have attached a screenshot of the design that I am getting below. Is there any way to change this to get to a structural design from here?
    • peteroznewman
      When you say structural mesh, I think you mean structured mesh.
      A structural mesh is used in a structural solution to calculate stresses on mechanical parts. Nothing to do with fluids.
      A structured mesh is a mesh that uses Hex elements instead of Tetrahedral elements. Please clarify what you mean.
    • kymani_Brown
      Think you for highlighting this error. I am referring to the structured mesh
