how we can define Case harden Material properties during the structural analysis
    • Manoj55
      If we are performing structural analysis on a solid case hardened rod, so its case 0f 0.5mm will be hardened.
      How we can add material properties in such case-harden parts, because its core will be soft.
      If we solve analysis with base material properties how we can relate with case harden material for understanding FOS.
    • peteroznewman
      Consider using a Surface Coating. That can have different material properties to the solid body that represents the core.
