September 15, 2020 at 4:20 pm
September 16, 2020 at 6:50 am
Naresh Patre
Ansys EmployeeHello DM
If you right click on the error message that says "mesh requires attention" you will see an option to select location. See below snapshot. This will help you identify the locations where mesh is failing.
The red colored mesh also indicates that the mesh has failed for that body. You can review that particular body and take appropriate action like cleanup, repair, add or modify mesh settings, etc.
September 16, 2020 at 7:47 am
d.matthis
SubscriberHello Naresh Patre
yes i also found the Select-Location-menu
but: nothing is selected (in my model) => i tried to change the filter (edge/face/body) no change
Then i found the solution: Switching between task output and geom => selection is visible
another detail-question : The red color is not easy for complex models / inside volumes
=> is the exploded view not available for mesh? -
September 16, 2020 at 8:10 am
Naresh Patre
Ansys EmployeeDM Clad to know that you were able to find the problematic location.
The Explode view feature is not available for mesh. I can understand the difficulty in visualizing complex models in such situations. You can try hiding bodies and faces to view the problematic regions.
3930
2649
1863
1272
610
