August 11, 2023 at 9:49 pm
mctom0518
SubscriberHello,
I have a question about the Ansys Academic Research CFD Lease (25 Tasks). How many cores per task (or cores in total) can be used to run simulations for this lease only?
If I were to add the Ansys Academic Research HPC Workgroup 128 Lease, I would get 128 cores; however, does this get added to the cores that come with the Ansys Academic Research CFD Lease (25 Tasks)?
For example, the Ansys Academic Research CFD Lease (25 Tasks) comes with 16 cores per task and I get the Ansys Academic Research HPC Workgroup 128 Lease. The 16 cores per task will not be added in the 128 Lease.
Thank you for the help!
August 14, 2023 at 10:25 pm
VJ
Ansys EmployeeHi, the Ansys Academic CFD Research license alone gives you access to run simulation on up to 4 cores. This is the capability of the base license itself. If you want to utilize more than 4 cores, you will need HPC licenses. HPC Workgroup 128 will effectively give you access to utilizing 128 cores on top of the 4 base cores. This means you can run a simulation on 132 cores at a time if you fully utilize your HPC workgroup + the CFD research base license.
August 14, 2023 at 10:27 pm
mctom0518
SubscriberHello VJ,
Thank you for your response. Is it 4 cores per task or 4 cores total?
August 14, 2023 at 10:28 pm
VJ
Ansys Employeeit is 4 cores per task
August 14, 2023 at 10:29 pm
mctom0518
SubscriberPerfect! Thank you for the clarification!
August 14, 2023 at 10:50 pm
mctom0518
SubscriberAlso, VJ, is there a way that I may check more information for my license. Unfortunately, I do not have the documentation at the moment, but is there a way I may check from my online account or through my university's computer cluster system?
I was not sure if my group had 4 or 16 cores per task. Because we were able to run much more cores per task, so it should not be 4 cores per task from our end.
August 15, 2023 at 6:34 pm
VJ
Ansys EmployeeIt is 4 cores per task. If you were able to run it with 16 cores, you were probably using HPC licenses.. If you are not able to run it with higher cores now, the HPC licenses could have expired. You can check with your license server admin.
Refer to included cores in this doc - https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/licensing/HPC_detail.html?q=base%20cores
- How to move duplicated ansys project position in workbench GUI
- unable to open files in ansys
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Error: Unable to open some designs in this project – Corrupted project files
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- ANSYS Multi field 2-way FSI data coupling issue
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- Material constant Damping calculation
- How to export high resolution images in APDL
7592
4440
2953
1427
1322
