HPC UDF compiling error
    • prebenjs
      When i try to run a UDF on a HPC I get the following error:
      make[1]: *** No rule to make target 'sink.c', needed by 'udf_names.c'.
      make[1]: Target 'default' not remade because of errors.
      WARNING: Auto-compilation of "libudf" failed. Please try to compile it manually.
      Error at host: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
      I've tried using dos2unix, compiling using built-in compiler and copying and tried manually compiling in the journal file. How can this be solves ?
    • DrAmine
      Is it a Linux cluster?
  • The topic ‘HPC UDF compiling error’ is closed to new replies.
