HTC on Graphic card
    • Abubakar
      I ran a Heat transfer simulation on a Graphic card but HTC which I got doesn't make any sense below I have shown the results which I got from the simulation.
      1. Nusselt number which I got from the simulation
      You might want to read the definition of the HTC you're calculating in the manual.
    • Abubakar
      Can you send me the link for the same?
    • DrAmine
      Just hit F1 if you are in Fluent then go to User's Guide and check the definitions.
    • DrAmine
    • Abubakar
      I have user guide I am searching for the page where the calculation of HTC is explained
    • Abubakar
      Please correct me if I am wrong Formula: HTC=q/(T_wall-Tcell)
      Fluent use above formula to calculate HTC and I am getting negative HTC coz of q.
      If I am correct I should not get NU=0 it should be some negative value, right?
    • DrAmine
      Does depend on which HTC you are referring default one us called surface HTC uses reference temperature from reference values.
    • Abubakar
      yes I am referring to Surface HTC
    • DrAmine
      Then ref temperature is used. Adjust it if you need that
    • Abubakar
      Sorry, I didn't get this. Actually, I wanted to know in my case what makes surface HTC negative and If HTC is something Nu should be zero, right?
      What is the heat flux through each of the wall and wall:shadow pair?
    • Abubakar
      do you want to see contour or an average value will be enough for you?
    • DrAmine
      It gets the sign of the heat flux ongoing or outgoing you might take only the absolute as it is a derived quantity. For first case add a screenshot of heat flux report fir the wall and its shadow
    • Abubakar
      Heat flux
    • DrAmine
      Almost nice. I do not see any issue. Just nusselt number might be not defined fir solid zone. I won't be irritated by htc or nusselt numbers as they are not used at all by the solver.
    • Abubakar
      sir & sir thanks for your clarification.
    • DrAmine
      Welcome and good weekend
    • Abubakar
      same to you!
Viewing 18 reply threads
