March 22, 2021 at 10:47 pm
isabellatubilla
SubscriberHello,I want to simulate SAR plots of a circular coil next to a hand. I am able to do so by importing a human hand from the ANSYS library. However, I want to have the hand be flat and parallel to the coil, and the ANSYS library hand is curved. Therefore, I am wondering how to take the humanaverage material, which is what the ANSYS human hand is made out of, and apply those properties to a simple block, then run the simulation from there. Is it possible to make other objects out of the humanaverage material? If not, is there a way I can replicate these properties into a new material I make on my own? I would be happy to do this but I do not know what those properties are, the ANSYS application does not give much detail about the properties of the humanaverage material.nThank you.n -
April 19, 2021 at 4:02 pm
Karthik R
AdministratorHello,nThank you for posting your question. Which tool are you using for your analysis?nKarthikn
Trending discussions
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
