April 4, 2023 at 7:46 am
Askar Gylymbekov
SubscriberHi guys! Could you tell me is it possible to obtain DF directly from ANSYS for HV insulator. Or can u show the other ways of finding it?
April 4, 2023 at 2:50 pm
Navya C
Ansys EmployeeHi Askar,
What are your application and input source values?
Which tool in Ansys are you using?
Navya
April 5, 2023 at 2:26 pm
Askar Gylymbekov
SubscriberHi!
It is 2022R
I can share a file if it is ok.
Askar
April 10, 2023 at 4:11 pm
HDLI
Ansys EmployeeHello Askar,
We may use electrostatic solver to calculate ideal C for lossless capacitance, and then use equations to get equivelent serie resistance (ESR) and the dissipation factor.
We also could use AC conduction solver to calculate conductance G (1/R) with conductivity of dielectric material, but this G would be parallel conductance and need to convert it to serie resistance (ESR).
Howard
- Maxwell, HFSS or Q3D?
- Error
5340
3345
2471
