October 19, 2018 at 5:31 am
mahmoud
SubscriberHi,
I am using Ansys Electronics Desktop 17, and I am trying to use HFSS Hybrid to simulate an antenna+reflector. In the Radiation boundary dialog, I can not find the option for "Model exterior as HFSSIE domain".
I was wondering if this option requires a special license.
October 19, 2018 at 4:28 pm
Karthik R
AdministratorHello,
I'm moving your question to the Electromagnetics thread for better traction. I hope this helps.
Best Regards,
Karthik
October 19, 2018 at 4:34 pm
mahmoud
SubscriberThanks Karthik.
October 19, 2018 at 6:31 pm
asamaiyar
SubscriberYes. If you have latest version of floating license, version 17 HFSS-IE will not work. Update to Electronics Desktop 19+. They have "Legacy Licensing" options in HPC and Analysis Options > Option. Just try to set it true/false (whichever works for you).
AS
- Maxwell, HFSS or Q3D?
- Error
2534
2066
1285
1104
459
