hydrodynamic diffraction mesh
    • maev5005
      I use hydrodynamic diffraction .
      After I clicked generate mesh, the message box came out.
    • Mike Pettit
      Unfortunately we can only tell from this that the Aqwa Workbench editor has crashed. Can you provide more context:
      Which version are you using?
      When did you install this version?
      What kind of geometry (panels/beams) are you trying to mesh?
      Are you meshing directly in Aqwa Workbench, or are you importing the mesh from a Mesh Component on the Project Schematic?
      Have you been able to run Hydrodynamic Diffraction with other models?
      Cheers, Mike
  • The topic ‘hydrodynamic diffraction mesh’ is closed to new replies.
