October 18, 2023 at 3:37 pm
mdti
SubscriberHi,
I am in need of support to model the viscous drag from the heave plate/skirt of the attached platform using Ansys Aqwa. My queries are as follows:
- I am aware that "Disc" can be used to model drag force from a heave plate. But do i need two discs at 6 (m) apart (see the figure)? If I have to use two discs, what could be the 'Disc Normal' values along Z axis?
- If it is possible to model the drag effect of the heave plate using a single 'Disc', what could be the ideal location (along height) and 'Disc Normal' value (along +ve or -ve z axis)?
- Please be aware that in the upper part (where small vertical cylinder connects to the heave plate) at the centre of the heave plate there is a hole. how to model a disc plate with a hole in it?
Cheers!
October 19, 2023 at 3:34 pm
Ingrid Machecler
Ansys EmployeeHello,
there has been similar questions on the forum. You might be interested in these:
https://forum.ansys.com/forums/topic/ansys-aqwa-can-we-draw-a-heave-plate-like-a-line-body/
Kind regards,
Ingrid
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3155
1688
1478
