Discovery Import
Discovery Import
hydrostatic load
    • Guillaume ANFOSSI
      Can we apply hydrostatic load in AIM ?
      Thanks,
    • Brian Bueno
      GUICAD
      I don't see an option for this, but I will consult with my team to see if it is possible.
    • Brian Bueno
      GUICAD
      You can apply a load that varies along a length using the function "Position.x".  You can also substitute ".y" or ".z".  This should be entered in the field where you would normally enter the numerical value.
      For example, 1000[kg/m^3] * 9.8 [m/s^2] * Position.z to define the calculation for ρ * g * h
      You just have to make sure the units resolve to the correct form.  You will then be asked to define a reference frame.  In most cases the Global Reference Frame should be fine.
