March 20, 2021 at 11:41 am
sdebode
SubscriberHow to apply hydrostatic pressure in APDL? I am modelling a floating structure and I want to study how hydrostatic pressure influences the deformation behavior.nnKind regards for your helpn -
March 23, 2021 at 12:28 pm
1shan
Ansys Employee,n Hydrostatic Pressure is applied directly on to the element faces using the SFCONTROL, SFE,,PRES and SFFUN (ansys.com) commands. Please check the help documentation links for details.nRegards,nIshan.https://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-helpn -
March 29, 2021 at 9:43 am
sdebode
SubscriberHi @1shan, thank you for your reply.nI was currently trying to model the hydrostatic pressure as an elastic support, as described on the following page: https://simutechgroup.com/a-normal-and-tangential-elastic-foundation-in-ansys-workbench-mechanical/ . However, I am not really certain about this method. Can you explain what the differences are between applying direct pressure to the surface, using one of the by you mentioned commands, compared to modelling an elastic support?nThanks a lot!nRegardsn
Trending discussions
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
