March 3, 2023 at 9:24 pm
Muhammad Tahir Faris
SubscriberHi,
I was trying to model baseball with hyperelastic material to get more insight of it. but I dont have values for unaxial and biaxial and strain stress test values. Can anyonline help how can I get this data. Any source which have these experiemental data or does anyone konw how can I use hyperelastic material for baseball without these experimental values.
thanks in advance
best regards
faris
March 6, 2023 at 4:25 pm
Armin Abedini
SubscriberHi Muhammad,
It is generally recommended to use as many experimental data as possible to calibrate hyperelasticity models but it is still possible to run the simulation with limited experimental data, such as only uniaxial tension data.
Please see the following courses to get more information on hyperelasticity models: -
March 6, 2023 at 4:32 pm
SubscriberI want to model baseball but I dont have experimental data. What should I do?
March 6, 2023 at 4:50 pm
Armin Abedini
SubscriberTo check available material data, you can look into the Ansys material database (Granta Materials).
You can also check the article below that may include helpful information for you:Modeling deformation behavior of the baseball - PubMed (nih.gov)
March 6, 2023 at 6:24 pm
SubscriberDidnot found anything related to my material in Granta Materials. and no data is given in the paper that I can use values from and define my own material. Please help me in it.
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3850
2629
1853
1246
600
