Ansys Products
Ansys Products
HYPERELASTIC MATERIAL IN MECHANICAL GPU SOLVER
    • Johnson Liao
      For the hyperelastic material in the Mechanical model, does it support GPU calculating?
      we did some tests, and found GPU loading is 0% during solving. therefore, let us confuse what happen it is.
      regs,
      Johnson
    • Ashish Khemka
      Hi Johnson,
      Please see if the following link helps:
      GPU Acceleration in Mechanical (ansys.com)
      Ashish Khemka
    • Johnson Liao
      Dear Ashish from Johnson,
      Thank you for your information, and after checking this help, it is no matter with the material issue in Mech GPU computing.
      we tested different material model, their performance is very signicant for GPU, like elastic, plastic, visoelastic, anand model.
      but for hyperleastic, its performance is almost zero.
      so, let us curious whether the hyperelastic ( Mooney-Rivlin) is not supported in 2022R2 Mech GPU solver.
      also investigate element_226 (structural-thermal-diffusion) , its result only 30% improvement.
      Rezoning only reduced 20% of using pure CPU solver.
      regs,
      Johnson
    • Ashish Khemka
      Hi Johnson,
      Thanks for the update. GPU accelerator does not support partial pivoting which is required for u-P formulation. Using hyperelastic materials which are generally incompressible and may need u-P formulation then using GPU may cause this problem.
      Ashish Khemka
    • Johnson Liao
      Thanks for your confirmation and information.
      Besides of Hyperelastic, are there any materials/elements not to be supported in Mech GPU?
      regs,
      Johnson
Viewing 4 reply threads
