July 5, 2022 at 11:51 am
July 5, 2022 at 2:57 pm
Guilin Sun
Ansys EmployeeThe error message says that the MoS2 material properties are not properly set. So please check, compare with other materials, and modify them properly. You may borrow some parameters from other material and check if it works. and than try to modify them properly.
- Error on Lumerical device
3744
2573
1793
1236
594
