January 27, 2022 at 2:03 pm
jaysoni1903
SubscriberWhenever I try to generate the mesh of the below-attached model, I get this error. If anyone could help I would really appreciate it. Thanks in advance.
January 28, 2022 at 12:45 ampeteroznewman
SubscriberYou should open the geometry in SpaceClaim and clean up the surfaces with Autoskin.
January 28, 2022 at 5:37 amjaysoni1903
I've tried that but still, the problem remains the same.
January 28, 2022 at 4:34 pmpeteroznewman
SubscriberHow many hours have you spent cleaning up the geometry? You need to do more. Not 30% more, but 300% more.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5242
3283
2467
