March 7, 2021 at 8:02 pm
Farhana1234
SubscriberMarch 8, 2021 at 9:33 amKeyur Kanade
Ansys EmployeeGo to %appdata% and go to Ansys folder. Then rename corresponding folder to *_old folder. e.g. if you have v201 then rename it to v201_old. Then check. nAre you able to open geometry? nIf this does not help, please create a discussion under installation category. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2700
2138
1355
1140
462
