October 17, 2018 at 6:10 am
October 17, 2018 at 6:27 am
Keyur Kanade
Ansys EmployeeCan you please check if you can open it in Design Modeler or SpaceClaim.
Make sure that your installation is correct.
Keyur
October 17, 2018 at 6:39 am
Rahul Kumbhar
Ansys EmployeeCan you try this. In Workbench go to Tools > License preference >> at the bottom select 'Use separate license for each application'
Regards
Rahul
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
