February 28, 2022 at 5:28 am
RUKAI
SubscriberI am using the structure model to do calculations on a linux system and encountered such an error. But the same cas works fine on windows system. Does anyone know why?
February 28, 2022 at 2:13 pmSaumadeep
Can you check the installation guide to verify that all prerequisites and libraries are installed?
Ansys, Inc. Linux Installation Guide
Regards, Saumadeep
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
February 28, 2022 at 3:41 pmMike Rife
Ansys EmployeeThis question is best asked in the CFD forum https://forum.ansys.com/categories/fluids since the message relates to Fluent and not a structural code (WB Mechanical etc). Also there should be a lot more to the error message that anyone looking into this will need. So can you get more in the screen shot? Does the Fluent model use a UDF?
2524
2066
1279
1096
457
