I am working with workbench using the linux cluster. I want to run Mechanical in batch mode. To solv
October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeThis can be done in two steps 1. Create a journal to open the file, update (to solve) and save. You can create a journal on a dummy file and later change its file names. •Open Ansys WB. Go to file >> Scripting >> Record Journal. Save the journal file and provide the name. •Open Dummy project file, update the project and save with other name. •Go to file >> Scripting >> Stop Recording journal •Go to journal file. Change the name of WB project to actual WB file and name to save after update. •Change the journal extension from .wbjn to .py 2. Use the following template to input shell commands to open WB and run journal in batch mode: <> -B -R <> For more information, please refer ANSYS R17.2 Help > Customization Suite > ANSYS AIM and Workbench Scripting Guide > Scripting Overview > Journaling and Scripting Guide. -
February 13, 2018 at 10:57 am
admin
Ansys Employeedwadwa
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- What is cause of error: display time for result item greater than the step end time?
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
Top Contributors
2656
2120
1345
1118
461
Top Rated Tags
