Discovery Import
Discovery Import
I cannot combine together solids. Why the sdoc fle is attached….Cannot merge bodies. (Operation failed because the faces and edges would c
    • sandor_toaso
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Cannot merge bodies. (Operation failed because the faces and edges would combine in a way that does not form a valid solid or surface.)
    • Charudatta Bandgar
      Hello SandorToaso
      Let me look into this, I will get back to you.
    • sandor_toaso
      any luck?
    • sandor_toaso
      will I get ever ysupport here?
      Hello SandorToaso I am also seeing similar behaviour, I am discussing it with the developers and the team. I will get back to you as soon as possible. Sorry for the trouble, since the issue is unusual it is getting difficult to pinpoint the reason.
      Regards.
      Hello SandorToaso
      I tried with two different ways, the way referred in the video is not at all ideal, but in case this issue is hampering your work, please proceed with this. Also, I checked with Discovery Model mode, and it is working as expected without any problem, hence it could just be an issue with SpaceClaim, I will investigate this further and let you know if there is any better workaround.
      Regards.
      Hello SandorToaso
      If you right-click on the geometry and do check geometry, zoom to fit,
      Body contains non manifold vertex. If you delete this faulty face, and try combining, it combines it well.
      Regards.
Viewing 6 reply threads
