3D Design
3D Design
I can’t add a sketch on the surface of a 3D torus.
    • Clemence
      I got a 3D torus on Design Modeler. My goal is to add the following geometry on the torus, but I can't find the way to do this on Design Modeler. Each time I create a sketch, it is in a plane (XY for example) and not on the torus as I would like it to be.
      Can you help me to do this please ?
      Thank you
      Clémence
      You're probably better off building the shape with a planar base and then cut/unite/intersect with the torus to create the object you want. Or start by adding a block and then slice bits off.
    • Clemence
      Thank you for your help, I think it will help me
