August 8, 2019 at 8:42 pm
Krishankant
Subscriberi tried the same following way to export file for tecplot but fluent not showing it in file type options
i go to flie>export>solution data>file type but the tecplot is not there.
i want streamline in tecplot but that option is not there in tecplot(i used data and case file) then from someone suggestion i you need to do from above method to generate correct streamline with labeling. but option is missing
please help me regarding this problem.
August 9, 2019 at 9:18 am
Ansys EmployeeI assume you scrolled down (the export list is slightly longer than the box), and that you're in serial. Some of the older export options don't work in parallel, and some aren't compatible with cutcell/hanging node/polyhedral cells.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2600
2088
1319
1108
459
